Just completed build, fan shroud issue
ShuhDonk
(@shuhdonk)
Hey all, I just completed my mk3s build and the only thing that seems wrong is the fan shroud, as it is a few mm's lower than the nozzle tip. Ideas what may be wrong to cause this? I went back through the instructions and everything seems installed correctly but obviously I am missing something. Ideas?
Thanks!
Respondido : 04/03/2019 6:34 am
RH_Dreambox
(@rh_dreambox)
Re: Just completed build, fan shroud issue
Can you attach some pictures of your extruder? An image tells more than a thousand words 🙂
Respondido : 04/03/2019 5:27 pm
ShuhDonk
(@shuhdonk)
I will do that but I broke the fan shroud messing with it last night so need to order some abs and print a new one. I did print a few things without the shroud, came out perfect! 🙂
I will update once I get the new part printed and put a photo up. thanks!!
Respondido : 04/03/2019 8:09 pm
