Issues loading filament
Hi All,
I recently replaced the hot end of my MK3s. Everything went back together good. After reassembly I ran the calibration wizard. Everything was good until I get to the point where it wants to print first layer test. The test starts and it loads the filament, then it unloads the filament. It does this about 3 times and says there is a MMU error loading the filament. I test it again and it will load the filament and put a blob in the upper corner. Then it stops saying there is a MMU error loading the filament. Most of the time it gets to the idler, I see the gear spinning like it's loading but then it goes in reverse right away to unload it. Has anyone else experience this, or know what's up?
Thank you for your time.
Respondido : 23/11/2021 6:02 pm
