Issue with first test Print, error message please unload filament.
duval105
(@duval105)
Hey just build my printer, and when I go to print the files that come with the SD card it stops right before it's going to print asks me to unload the filament, reload filament and then when I've done that it goes right back to try and print again and the same unload filament comes up. I'm using the PLA that came with my printer and a PLA I had before to test if that's the issue. Has anyone run into this issue before?
Opublikowany : 10/12/2019 8:56 pm
Dave Avery
(@dave-avery)
RE: Issue with first test Print, error message please unload filament.
misadjusted IR sensor
Opublikowany : 10/12/2019 9:57 pm
1 ludzie polubili
rmm200
(@rmm200)
Until you get the sensor working - disable it in Settings. At least then you can print - but you will have to tell it to load filament.
Opublikowany : 10/12/2019 10:27 pm
1 ludzie polubili
duval105
(@duval105)
@robert-rmm200
thank you that worked appreciate the help
Opublikowany : 11/12/2019 1:28 am
guyennon.sophie
(@guyennon-sophie)
Same problème for me but i world like to Get this functionnality what s wrong in thé assemblé?
Opublikowany : 11/12/2019 5:10 pm
