Is there a cover on the display?
Razor
(@razor)
Stupid question, I just received my first assembled MK3S today. 👍🏼 Is there a peel away protector on the display? It looks like there is, but I don’t see an easy way of removing it. Before I potentially go messing something up I wanted to ask here first. 😆
Best Answer by Razor:
Never mind, figured it out. There is a scratch cover, and unfortunately you have to take the display apart to remove it because it is larger than the frame around it. When it was assembled at the factory they probably should have removed it, then reapplied to the outside of the housing. Wonder how many of those assembled printers are out there with the scratch cover still on? 🤔
Mini+MK3S+XL 5 Tool
Napsal : 07/11/2022 10:30 pm
Razor
(@razor)
RE: Is there a cover on the display?
Mini+MK3S+XL 5 Tool
Napsal : 08/11/2022 3:47 am
