[Rozwiązany] Is my extruder jammed?
Gungrav3
(@gungrav3)
Lately my printer has been "under-extruding" or missing layers. I am doing a first layer calibration below and as you can see some of the sections are missing. I have cold pull numerous times and nothing looks to be jammed. I have also hand pushed filament through and it comes out good. I don't know what this could be unless that there is something jammed inside the extruder and i would have to take it all apart. Please help me out. I appreciate everything.
Opublikowany : 09/06/2019 10:56 pm
gnat
 gnat
(@gnat)
RE: Is my extruder jammed?
Are you hearing clicking from the extruder? If not, it's probably not jammed.
My guess:
  1. Give the PEI sheet a good clean (warm water and dish soap (with no additives or scents) and give it a good wipe down with 90+% IPA).
  2. Drop your Live Z a fair bit more.
  3. Maybe tighten your idler tension a bit.
What I'm seeing suggests that the Live Z is too high and your sheet may not be clean and these are causing adhesion issues.
It's also possible that the idler is too loose and its not feeding consistently.
MMU tips and troubleshooting
Opublikowany : 10/06/2019 12:10 am
Snap a photo of the filament end after a jam: do a normal UNLOAD and post a photo of the tip.  A photo of one of your cold pulls may also be helpful.
I disagree a bit with Gnat on Z-offset; it's probably okay for now, at least until you get the extrusion issue resolved, then you can work on tuning Z.   I agree with him on idler tension: there seems to be a sweet spot: too little and you get skips; too much and you get skips.
Also - it helps to know which printer you have, and whether you also have an MMU attached.
Opublikowany : 10/06/2019 2:16 am
Gungrav3
(@gungrav3)
So i found what the culprit was...the bolt with the spring that tightens the extruder was too loose. Tighten it up, and it works great
Opublikowany : 11/06/2019 3:03 am
1 ludzie polubili
gnat
 gnat
(@gnat)
Glad you got it sorted.
Opublikowany : 11/06/2019 4:10 am
