Is it some kind of Layer Shift?
Thomas S.
(@thomas-s)
Got some new problems, not sure if this is some kind of Layer Shift 😕
For now i checked all axes, couldn´t find any problem. The belts are also mounted well. At least it looks right for me.
Thanks for help.
Edit: Add more zoomed picture
Opublikowany : 10/09/2018 9:24 am
webshadow
(@webshadow)
Re: Is it some kind of Layer Shift?
you might wanna get a little closer with better lighing and from more angles 😉
Opublikowany : 10/09/2018 2:17 pm
nathan0876
(@nathan0876)
Looks to be small layer shifts on X only axis. Check X belt and pully/grub screw and make sure everything is tight.
Opublikowany : 10/09/2018 4:56 pm
Thomas S.
(@thomas-s)
So i got it 😀
Was my own fault. The belt was too tight. Some weeks ago i found this description: https://prusacommunity.com/your-belt-status-and-you/ and tried to get my belt status between 255 and 270. Started from about 285. But could not get below 280. As i have seen now even that was to much.
Thanks for help
Opublikowany : 11/09/2018 6:55 am
