Inconsistent Layers
JohnP
(@johnp)
Inconsistent Layers
I would call it layer shifting but in my case the print anomaly exists right around the object and not just in the x or y direction. I have checked the usual suspects such as the grubs screws and belt tension.
Any suggestions would be appreciated.
Napsal : 10/03/2019 3:36 am
Paul V
(@paul-v)
Re: Inconsistent Layers
Looks to me as if the fillament is "cupcaking" over the previous layer.
Could be issues in Z guidance/screw-threads, is it on the same height with every print?
Could be issues with temperature/fan speed but that is unlikely to be as uniform as in the picutre.
Napsal : 11/03/2019 9:27 am
bunc
 bunc
(@bunc)
RE: Inconsistent Layers
@paul-v18 @grant-c3
I’m getting this same thing on my new Mini. The imperfections are always at the same Z height regardless of what I’m printing. Did you find any solutions?
Napsal : 13/11/2020 5:48 pm
These seem to be similar to known issues slicing with Slic3r/Plicer. Try slowing down the print speed, a lot. On enable Thin Wall detection.
The artifacts tend to occur when internal geometry changes, and layer print times change by a large percentage. I've also turn down the cooling criteria so the printer prints at roughly the same speed regardless of layer times - but this is probably not recommended for all case.
Napsal : 13/11/2020 11:45 pm
