i3mk3s upgrade problems printing .01 layer
Dschiri1
(@dschiri1)
Ive just finished upgrading my mk3 to mk3s. Im having a hard printing parts at 0.1 layer. I have yet to get anything to print at 0.1 layer hight. One failed at 15mm high and another one at 25mm high. The pla filament keeps jaming around the bondtech driver and ptfe tube. All 0.15 layer part print perfectly. Im using new pla with standard prusa pla settings. Any ideas on method to test for problems? .
Thanks
Respondido : 12/03/2019 6:17 pm
Re: i3mk3s upgrade problems printing .01 layer
A partially plugged nozzle can cause this, as can debris that gets trapped in the PTFE and heat break.
Do a couple cold pulls, and then remove the nozzle and blow air up through the filament path to clear out any accumulated dust.
Respondido : 13/03/2019 6:17 am
toaf
 toaf
(@toaf)
make sure you are trying to print at .1.
.01 is work to print at.
Respondido : 13/03/2019 6:24 am
Dschiri1
(@dschiri1)
Re: i3mk3s upgrade problems printing 0.1 layer
Sorry decimal point is in wrong place in title correct in body. How do you edit title after submitted. I cant figure our how
Respondido : 14/03/2019 2:10 am
toaf
 toaf
(@toaf)
is the ptfe tube locked in with a clip? maybe it's jumping up
Respondido : 14/03/2019 3:00 am
Calire
(@calire)
Perhaps "editing" the first post where you can access at the title (?)
Respondido : 14/03/2019 7:15 am
