how to reseat the pfte tubing
islander2013
(@islander2013)
Hey guys,
need help with my mk3s which is only a week old now... today when i changed from PETG to PLA i noticed it took a few tries to get the filament oozing the correct color... then mid print it stops producing filament.
opened the extruder door and noticed the PLA was jammed a little, so i heated up hot-end and was able to pull it out using the unload setting. however, the pfte tube now sits a little lower and the filament doesn't go into the hole. The gears try to push it in, and the gears are aligned ok but because of the drop on the tubing i cant get it to feed into it.
does anyone know if i could try pull it back up with some needle nose pliers if i put them on the inside of the tubing and pull? i saw the below guide about replacing the tube, but i really don't want to have to go through all that, mainly as i just put the thing together...
help appreciate guys...
https://manual.prusa3d.com/Guide/How+to+replace+PTFE+tube/82
Publié : 06/04/2020 5:44 pm
