How to remove the extruder thermistor cable from the EINSY board?
prusanewuser
(@prusanewuser)
Hi, what is the best way to unplug the cables from the EINSY board? While it is very easy to just unplug the Extruder heater red cables from the board, I cannot just unplug it by pulling. Doing so could damage the socket on the board or the cable.
Publié : 24/07/2019 1:15 pm
RE: How to remove the extruder thermistor cable from the EINSY board?
There is a clip, I think. Just depress it and the plug should come loose with no effort.
Publié : 24/07/2019 2:37 pm
prusanewuser
(@prusanewuser)
Do you mean the clip in the middle? I cannot see from your photo clearly. I think I saw it in person and pressed it but I could not get the cable out.
Publié : 24/07/2019 2:44 pm
Publié : 24/07/2019 2:56 pm
Phrue
(@phrue)
I’m also having trouble removing the extruded thermistor despite the clip being clearly depressed. Did you ever find a fix?
Publié : 24/09/2021 4:47 pm
JPLau001
(@jplau001-2)
You need to press the top part of the clip lever on the cable plug towards the cable before pulling on the plug. That will release the catch on the lower inner bottom side of the clip lever and the plug should then slide off easily.
Publié : 26/09/2021 3:00 pm
