How to Remove ASA from heatbed?
In the picture you Van See the Prusament ASA on the printbed
i cannot get it off. Any ideas?
Respondido : 13/02/2020 5:34 pm
RE: How to Remove ASA from heatbed?
Only solution I have is print the same object on top.
Then freeze your plate and try to pop it off. Otherwise consider it a learning experience and print on the other side of the sheet. May need to sand down that failure first.
Next time - use one of the recommended ASA release agents first. I think glue stick is popular.
Respondido : 13/02/2020 6:15 pm
Topic starter
answered:
@robert-rmm200
Okey thanks and this will probably work?
Respondido : 13/02/2020 6:30 pm
Printing the same object on top is an old trick to remove residue. Nothing beats adhesion like more of the same.
Works well for PLA. YMMV...
Respondido : 13/02/2020 6:34 pm
Topic starter
answered:
@robert-rmm200
- Okey Thanks, there Are no Problem with pla or other Material only asa
Respondido : 13/02/2020 6:47 pm
