Hotend bottom and nozzle dirty
Hi there,
I have had several cases, when trying out different filaments and switching beds, that the print got loose and started to move around, with as a result a huge blob of filament stuck to the nozzle en bottom of the hotend. I tried to clean that out but still... When you look at the pictures below, is this a "normal" looking hotend and nozzle ?
Opublikowany : 21/05/2020 5:02 pm
RE: Hotend bottom and nozzle dirty
A lot of people have this problem when they get a Blob of Doom...
If you use a Brass Wire Brush on the hot, hotend, this should mostly sweep away!
Opublikowany : 21/05/2020 7:20 pm
2 ludzie polubili
