Horrible Blob and I screwed up the wires... help
GMXIX
(@gmxix)
I had been printing fine, got the printer up and running, printed several parts, then left it running last night on a larger print.  Unfortunately I had left the fan on in my room and that in combination with the AC I believe deformed the part and it peeled off the bed, then created a blob, and eventually stopped with a crash detection.  (The first 10 layers had already been down and looked good so I thought it would be fine to leave alone).
So I watched the video on removing blobs, preheated and began to remove the blob.  Unfortunately it pulled the small black wire out of the hot- end, and the white heat shielding off the wire.  Now I'm not sure what the best way to fix this is.
Full size images here: https://imgur.com/a/ITuO0SB
I'm assuming that wire is to help determine the internal temp.  So how to I recover from this 🙁  Had the printer working for about a 2 days.
Best Answer by GMXIX:
Opublikowany : 08/07/2019 5:01 pm
RE: Horrible Blob and I screwed up the wires... help
Looks like you need a new Hot End Thermistor
Available from:
Prusa eShop,  Don't forget to log in...    https://shop.prusa3d.com/en/mk3mk3s/205-mk3-hotend-thermistor.html
E3d-online.com (UK)                                https://e3d-online.com/catalogsearch/result/?q=thermistor+replacement+kit
E3dResellers                                                https://e3d-online.com/resellers
Opublikowany : 08/07/2019 8:12 pm
GMXIX
(@gmxix)
Yeah, after watching several videos I arrived at that conclusion.  Is replacing them documented somewhere?
Opublikowany : 08/07/2019 8:16 pm
vintagepc
(@vintagepc)
Be sure to also add a silicone hot end sock to your shopping list; in addition to helping stabilize the hot end temperature, it prevents the plastic from completely sticking to the heat block and blobbing up on it next time a part detaches; it'll only be able to stick to the exposed nozzle area and more likely droop and fall off on its own accord rather than engulf everything.
Opublikowany : 09/07/2019 1:38 am
1 ludzie polubili
