Help with troubleshooting failed prints
derekwf
(@derekwf)
Hello, first post here.
I recently put together a Mk3 kit. The initial setup went perfectly, and I quickly printed off a flawless triceratops skull and 3 sets of gears for the kids.
Every other print has failed, from the included 50micron frog, to a butterfly and garbage can that I’ve printed on other printers before.
Do I need to be putting glue on the steel sheet?
I’ve tried using Cura (with mk2 settings), and Prusa Control.
Here is the failed frog from last night. All the failed prints seem to happen from the nozzle bumping the bottom of the print and moving it.
Veröffentlicht : 17/05/2018 2:59 am
Rosparovac
(@rosparovac)
Re: Help with troubleshooting failed prints
I think you problem is the last one from this article:
https://www.prusaprinters.org/how-to-fix-the-most-common-3d-printing-errors?utm_source=facebook&utm_medium=cpc&utm_campaign=5_errors
Try this one
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Veröffentlicht : 19/05/2018 9:34 am
