Help With Power Supply Upgrade
My original power supply died (or so I thought) and I replaced it with a MEANWELL LRS-350-24 350.4W 24V 14.6 Amp as suggested on a couple of forms. I am now wondering if my power supply was fine and the issue may have been with the circuit board attached to the power cord that provides the power panic mode. I can get my printer to work fine by disconnecting the power panic cord from the rambo board and connecting power directly to the new PSU. When I try to power my new PSU through the Prusa power receptacle with attached Power Panic board I get no power to the PSU. I have checked all the connections and something unusual seems to be happening. The ground and the neutral contacts are connected to the lower and left prongs from the 3 pron plug however the hot cord is not connected to the other prong from the 3 prong cord. The only place the "hot" prong seems to be connected to is a strip of metal on the other side of the receptacle that seems to have no connection to the circuit board. I wonder if something didn't break or short out. Hopefully the picture below makes things clear. I think I may have to buy a replacement Power Panic module or just live without it. Any suggestions would be appreciated.
RE: Help With Power Supply Upgrade
Isn't there a fuse in the power plug? It connects to hot, then the other side to the PP board?
