[HELP] tips/feedback needed for a failing print
simisimis
(@simisimis)
Hi guys, I've just recently received Prusa MK3S+ kit and boy am I happy with it.
As a test drive I printed couple of things I've found on prusaprinters, As I calibrated the printer for the first time, during the first layer I had to adjust Z to -1100. It printed 2 prints fine.
But then I wanted to print this file from thingiverse: https://www.thingiverse.com/thing:105047
I used prusa slicer to create gcode. left all defaults(0.15 quality) only after two unsuccessful prints I added a brim.
Base with brim is 6.5cm long and 3.5cm wide.
I use prusa provided silver PLA  on a default heat plate with default 0.4 nozzle. I tried cleaning it with isopropyl, then rubbing with a glue stick that was provided in a kit. I had to readjust Z as in the pics you see I made Z -1400 and it still feels like I should lower it more(check how rim lines aren't connected). Or should I do the opposite and raise Z?
[img] [/img]
[img] [/img]
I was hoping to print, see what fails and adjust, however I am not sure which way should I be heading so if you instantly see something that could help me to jumpstart this learning process I'd appreciate it very much.
Posted : 24/04/2021 6:37 pm
RE: [HELP] tips/feedback needed for a failing print
set the printer to use 7x7 mesh bed levelling (LCD)
Use     'Life Adjust 'Z' My Way'  to set live Z (First layer calibration)
make sure your build plate is absolutely clean...
I use hot water, a touch of detergent and a new dish sponge. to really clean the build plate... and rinse with hot water, then dry immediately with Paper towels.
then use the heatbed at 70C for PLA...
Posted : 24/04/2021 7:04 pm
simisimis
(@simisimis)
this is incredible, I started with your PLA test, in the first half of test pattern it was clear that i had to drop Z to -1550.
then tried printing with new settings and it worked even when I accidentally started a gcode file that did not have a rim.
thank you so much!
Posted : 24/04/2021 11:05 pm
