help printing at .05
toaf
 toaf
(@toaf)
I have a model I made of the Tardis and I can print it at .2, .15, and .1 just fine. but when I try it at .05 it always seems to start having extrusion/retraction issues at the heavy retraction parts.
I've played with extrusion multiplier, retraction settings, some speed. I'm almost out of ideas to try.
Postato : 28/07/2018 11:25 pm
toaf
 toaf
(@toaf)
Re: help printing at .05
and yes the filament gears are messed properly.
Postato : 28/07/2018 11:27 pm
toaf
 toaf
(@toaf)
forgot to say what the problem was.. ooops (i cant find an edit" for post)
at some point the extruder starts "clicking" i cant really tell if its slipping form the hot end being full of filament or the filament just started slipping on the gears from all the moving going on. i will try printing it at crazy slow speed to see if that helps.
Postato : 28/07/2018 11:34 pm
toaf
 toaf
(@toaf)
the .05 in that picture i did try to fix it by reloading filament a few times. but then let the gods watch it the rest of the way.
Postato : 28/07/2018 11:53 pm
Erik
 Erik
(@erik-3)
Printing at 0.05 can be a bit tricky. What worked for me (before R3 parts) was to increase the heat and remove retractions. I haven't tried printing 0.05 since upgrading to the R3 parts, but with the improved cooling of the heatsink I may start fiddling with it again to see what tweaks need to be made.
Postato : 30/07/2018 2:30 pm
RufusClupea
(@rufusclupea)
Did you adjust for the relative dimensions in space? 🙄 😀
That's "MISTER Old Fart" to you!
Postato : 30/07/2018 4:37 pm
toaf
 toaf
(@toaf)
I finally got my .05 Tardis. when I used prusa control it was like magic. so some crazy setting in slicer must be off. it's a shame the slicer defaults aren't the same used in prusa control. at least I finally got it.
Postato : 02/08/2018 12:47 am
