help printing at .05
I have a model I made of the Tardis and I can print it at .2, .15, and .1 just fine. but when I try it at .05 it always seems to start having extrusion/retraction issues at the heavy retraction parts.
I've played with extrusion multiplier, retraction settings, some speed. I'm almost out of ideas to try.
Re: help printing at .05
and yes the filament gears are messed properly.
forgot to say what the problem was.. ooops (i cant find an edit" for post)
at some point the extruder starts "clicking" i cant really tell if its slipping form the hot end being full of filament or the filament just started slipping on the gears from all the moving going on. i will try printing it at crazy slow speed to see if that helps.
the .05 in that picture i did try to fix it by reloading filament a few times. but then let the gods watch it the rest of the way.
Printing at 0.05 can be a bit tricky. What worked for me (before R3 parts) was to increase the heat and remove retractions. I haven't tried printing 0.05 since upgrading to the R3 parts, but with the improved cooling of the heatsink I may start fiddling with it again to see what tweaks need to be made.
Did you adjust for the relative dimensions in space? 🙄 😀
That's "MISTER Old Fart" to you!
I finally got my .05 Tardis. when I used prusa control it was like magic. so some crazy setting in slicer must be off. it's a shame the slicer defaults aren't the same used in prusa control. at least I finally got it.
