Help please made a noob mistake
Davisem
(@davisem)
I used too much force and now the nut is loose and when I try to turn the screw it moves with the nut and doesen't come out, any tips on how to get it out appreciated thanks! (Do you think it's possible to use again this piece or should I print it new?)
Opublikowany : 21/09/2019 11:40 pm
JMH714
(@jmh714-2)
RE: Help please made a noob mistake
Seems like you'll have to print a new one.
To remove nut - try superglue to nut (carefully not to put glue on bolt thread) or stick something to hold bolt while unscrew the bolt?
Opublikowany : 22/09/2019 2:33 am
