Help! Checking Y-Axis: Axis Length
will.gunter9
(@will-gunter9)
Hi!
I just got finished building my MK3S and I am going through the self test. I got to the y-axis and it seems to be skipping over the belt and making a VERY loud noise. I have attached a video of the process. I have tried tightening the screw between the two printed parts below the y-axis but that has not helped at all. Any advice?
Thanks!
This topic was modified 6 years temu by will.gunter9
Opublikowany : 27/06/2019 2:03 am
Bunny Science
(@bunny-science)
RE: Help! Checking Y-Axis: Axis Length
I see the y-pulley continue to spin after carriage reaches end of motion. Y-belt tension is too loose.  Loosen the y-adjust and re-clamp y-belt in tighter tooth position. That should give you enough adjustment range to set proper tension.
Opublikowany : 27/06/2019 9:21 pm
