Heater /Thermistor Not Connected
doot doot beep
(@doot-doot-beep)
Hi all,
Just finished assembly and running through the self tests. I keep getting Heater/Thermistor not connected failure on the Heatbed. I checked the wiring, the thermistor for both the heatbed and hotend, and the power wiring are in the right spots on the PCB. I removed the little cover for the heatbed powerfi and re-tightened the power on both ends. The LED on the hotbed lights up for a little bit then turns off.
I updated the firmware. Oddly enough, before I updated the firmware, the heatbed was passing the test but I was getting the same error on the hotend test.
Posted : 26/05/2019 3:38 am
