Heatbed Step 2 in Heatbed & PSU assembly
raknor7
(@raknor7)
Another broken part. Can i use this part?
Yes, this is copper.
Or could i use something to secure scratch?
Postato : 27/09/2019 4:09 am
Utenti
RE: Heatbed Step 2 in Heatbed & PSU assembly
I would start a chat with support.
Postato : 27/09/2019 2:47 pm
if that fails, a little clear  nail varnish would cover it!
Joan
Postato : 27/09/2019 4:16 pm
raknor7
(@raknor7)
@joantabb
What is the name /nail varnich/ and what is the temperature resistance?
Postato : 27/09/2019 6:33 pm
Utenti
Be careful with nail varnish.  Some that is made with Nitrocellulose which is flammable.  It is a primary ingredient used to light rocket motors.
Postato : 27/09/2019 7:05 pm
raknor7
(@raknor7)
Oh, now i see..
I must cover it whit nail varnich and burn it.
A thin layer of carbon => will be an insulator
Postato : 27/09/2019 7:15 pm
@raknor7
you dont actually need an instuator. both the PEI stickers and the powdercoat PEI will protect your heat bed from contact with anything electrical
Postato : 27/09/2019 7:29 pm
And the coating on the fiberglass is nothing special, either. Sometimes epoxy based, sometimes made from the same materials as what you find in paint and nail polishes.
https://en.wikipedia.org/wiki/Solder_mask
Postato : 27/09/2019 9:12 pm
