RE: Heatbed Step 2 in Heatbed & PSU assembly
I would start a chat with support.
if that fails, a little clear nail varnish would cover it!
Joan
@joantabb
What is the name /nail varnich/ and what is the temperature resistance?
Be careful with nail varnish. Some that is made with Nitrocellulose which is flammable. It is a primary ingredient used to light rocket motors.
Oh, now i see..
I must cover it whit nail varnich and burn it.
A thin layer of carbon => will be an insulator
@raknor7
you dont actually need an instuator. both the PEI stickers and the powdercoat PEI will protect your heat bed from contact with anything electrical
And the coating on the fiberglass is nothing special, either. Sometimes epoxy based, sometimes made from the same materials as what you find in paint and nail polishes.
