[Solved] Heat Bed Height Issues
JSGhost
(@jsghost)
I sent an email about this, but might as well see if I can get some assistance in the chat 🙂
Basically I mounted the heat bed too high to the point where the I can't swing the einsy door in chapter 8 without it hitting the heat bed.
Can you guys help me pinpoint the issue and how to mount the heat bed lower?
I was feeling good about my build up until this step.
Thanks
Best Answer by RH_Dreambox:
It looks like you've mounted the door upside down.
If you turn it right you should also be able to close it 🙂
This topic was modified 5 years ago by JSGhost
Posted : 13/08/2019 4:22 am
RH_Dreambox
(@rh_dreambox)
RE: Heat Bed Height Issues
Posted : 13/08/2019 11:03 am
JSGhost liked
JSGhost
(@jsghost)
Posted by: RHDreambox
oh you're right, good catch! I have more than enough space now for the door to swing! I'll re-attach the heat bed the way I originally did with the spacers below it and then continue on with chapter 8. Thanks again!
This post was modified 5 years ago by JSGhost
Posted : 13/08/2019 11:53 am
