going up
eran.r2
(@eran-r2)
going up
Hi
We received the MK3
Calibrated Z
Why is one corner going up ?
See pictures
Regards,
Eran Reshef
Veröffentlicht : 30/04/2018 2:27 pm
RH_Dreambox
(@rh_dreambox)
Re: going up
There may be two reasons for this.
1) The Z level of the first layer is too high. Adjust the Z level until you get a fine first layer.
2) The bed is not properly cleaned. Wash the surface with a mild soap solution and water.
Veröffentlicht : 30/04/2018 3:55 pm
eran.r2
(@eran-r2)
Re: going up
Hi
the first layer was flat ( horizontal) in the beginning , after 3-5 mm of printing this phenomena started - the corner raised
bed was clean
Veröffentlicht : 01/05/2018 9:55 am
rob.l6
(@rob-l6)
Re: going up
So cause 1 above is probably the issue then. Have you tested your z offset (live Z) calibration with some calib squares?
Veröffentlicht : 01/05/2018 10:29 am
Rainer
(@rainer)
Re: going up
If you show a closeup picture of the bottom layer, that would help us .....
Blog: https://schlosshan.eu
Thingiverse: https://www.thingiverse.com/rainers/collections/rainers-customizable-things
Prusaprinters: https://www.prusaprinters.org/social/6508-rainer/collections/6900
Happy printing 😉
Veröffentlicht : 01/05/2018 12:26 pm
eran.r2
(@eran-r2)
Re: going up
see pictures
Veröffentlicht : 01/05/2018 12:45 pm
eran.r2
(@eran-r2)
Re: going up
one more
Veröffentlicht : 01/05/2018 1:09 pm
eran.r2
(@eran-r2)
Re: going up
I would like to say again
The first layers were flat then there was a deformation and the corner was "raised"
See picture
Veröffentlicht : 01/05/2018 2:24 pm
RH_Dreambox
(@rh_dreambox)
Re: going up
And I'll say it again ... clean the bed! You may think the bed is clean, but the printer does not like it.
Use a mild soap solution, no chemicals.
Veröffentlicht : 01/05/2018 5:47 pm
GertL
(@gertl)
Re: going up
And ill repeat
This will solve your issue.
Gert
Veröffentlicht : 01/05/2018 7:00 pm
eran.r2
(@eran-r2)
Re: going up
OK
will try !
Veröffentlicht : 02/05/2018 1:26 pm
eran.r2
(@eran-r2)
Re: going up
is there a possibility that the heat of the BED in that area is not high enough ?
Veröffentlicht : 02/05/2018 1:29 pm
stahlfabrik
(@stahlfabrik)
Re: going up
Nope highly unlikely.
Clean the bed. Use a bit of acetone once a week at maximum. Between every print use IPA.
Use paper towels and throw them away. Do not reuse them.
What you see is called warping. With pla and PEI sheet it is a sign for grease on the bed or too high first layer.
Veröffentlicht : 02/05/2018 7:39 pm
