General problems after printing a few things...help
marcin.c4
(@marcin-c4)
1. There were problems with the calibration of the X axis. I noticed that the cable harness together with the zipper hit the power supply. I took the zip fasteners and the problem disappeared.
2. After a successful calibration, selecting an autozero, the extruder does not return to the point 0,0, only 5cm to the right. If it wants to release the printout, it is impossible to level the tops, because the third point goes beyond the table. If I manually move it to the left, it's ok, but is that what it is about to move it down to the left before printing?
3. I can not print in normal mode, only in silent mode, because immediately I detect a collision that is nowhere to be found, the only thing that comes to my mind is the fact that the bearings are damaged (but this is unlikely) because the extruder does not move hard . What's worse, after the collision is detected, the extruder does not go to the same place to continue printing, it only moves 5-10cm along the X axis. I would not like to print continuously in silent mode, please help me.
Veröffentlicht : 23/07/2018 10:17 am
