Gaps in corners
Hi all, first post here. I'm not sure how to upload a .3mf file. I'm getting these gaps in corners. I changed the perimeter engine to Classic. For the most part these are stock .2mm speed profiles, or .3mm draft. All profiles have the same issue, tested multiple filaments, I tried drying the filament but it also happens on a fresh roll.
My retraction is also at stock at .8mm @ 35mm/s. Any help is appreciated.
Napsal : 18/02/2023 2:17 pm
Topic starter
answered:
RE: Gaps in corners
For anyone that might come across this... this article solved my issue: https://help.prusa3d.com/article/linear-advance_2252
My LA K value was .05 by default. I was between .02 and .03 and after a bunch of test prints I decided on .03.
Napsal : 21/02/2023 11:59 pm
