Gaps around edges
Fredrico
(@fredrico)
Gaps around edges
I've recently put together my i3 MK3S+ kit, and have tried several prints from those included on the SD and some from other sources using PrusaSlicer. Most/all prints have a noticable gap around the edges, with the edges/walls sometimes appearing out of position.
I'm using the Prusament PLA that came with the kit, and have not tested with other filament.
I'm assuming its an issue with the way I built it, but not sure where to check. Any ideas?
Thanks in advance!
Publié : 23/08/2021 8:21 am
Membre
RE: Under extrusion
This is under extrusion.  You may have your idler too loose or a partial jam.
Publié : 23/08/2021 8:45 am
Membre
Offset and timeout
You also have a z offset that is too high.
Publié : 23/08/2021 8:47 am
BogdanH
(@bogdanh)
Posted by: @cwbullet
We can't see 1st layer on photo, so what makes you thinking that?
[Mini+] [MK3S+BEAR]
Publié : 23/08/2021 10:19 am
Fredrico
(@fredrico)
Tightening the idler
Thanks for the replies.
I tightened the idler a fair bit, but the issue is still present (see below). Is there such a thing as over tightening the idler? Should I keep tightening?
Also, I made the z offset lower too, but not sure if it made a difference. What should I be looking for here?
Thanks again.
Publié : 23/08/2021 10:47 am
