Gabs between lines no sticking on bed
Ewolin
(@ewolin)
Have had the printer for 8 months so far no problems recently it is making these gaps when calibrating the first layer. The Z calibration is very well adjusted. Didn't change anything when printing the calibration. He does the front layer perfectly, but he does the lines all with gaps and poorly. In addition, not a single print sticks to the bed without rubbing in 4 layers of glue, that wasn't the case before. Thin line prints will not stick to the bed even with glue. What can I do? Thanks.
Opublikowany : 21/01/2023 2:07 am
RE: Gabs between lines no sticking on bed
These tips might help you:
https://help.prusa3d.com/article/clogged-nozzle-hotend-mk3s-mk2-5s_2008
https://help.prusa3d.com/article/under-extrusion_2007
wbr,
Karl
Opublikowany : 21/01/2023 11:30 am
1 ludzie polubili
Please report back if you were able to solve the problem with above tips - thanks!
wbr,
Karl
Opublikowany : 22/01/2023 1:01 pm
Ewolin
(@ewolin)
I did a complete maintenance of the printer and cleaned everything and then oiled the necessary components. Then I changed the nozzle now everything works fine again, apparently the nozzle was the biggest problem thanks for the help.
Opublikowany : 22/01/2023 2:47 pm
