fucked up prints after nozzle change
max.b5
(@max-b5)
Good day,
i have a i3 mk3 since more than a week and have successfully assembled and printed over the last week.
i generally had no issued and have been satisfied with everything.
in order to inprove print speed i purchased a .6mm nozzle on amazon china no name, installed it according to the youtube video adjusted my Z and started to print. however the print results are very bad ( i use purse control with .6 nozzle adjusted in settings).
i thought i bought a bad nozzle on Amazon, and reinstalled the original .4 nozzle, however now i have the same problems than i had with the .6 nozzle...
for better reference please have a look at the pictures:
what im doing wrong?
Veröffentlicht : 12/08/2018 4:21 pm
max.b5
(@max-b5)
Re: fucked up prints after nozzle change
one more picture with two parts, the left done with original nozzle, the right the .6 nozzle result.
fillament is original grey PLA from the box.
Veröffentlicht : 12/08/2018 4:23 pm
Try the Slic3r 0.6mm profile directly
Re adjust live Z after changing the nozzle.
Using default slic3r settings
See if the result is the same
Regards Joan
Veröffentlicht : 12/08/2018 4:54 pm
max.b5
(@max-b5)
thank you, i will do so with the nextprint. however i have now been back to mz initial printer status with the .4 nozzle... how is the change in print quality there explainable?
Veröffentlicht : 12/08/2018 5:23 pm
Have you restored everything to the same condition as when it was working properly before
I accidentally opened the mk2 mmuv1 profile on slic3r after a nozzle change...the mk3 didn't like it
Regards Joan
Veröffentlicht : 12/08/2018 5:44 pm
