frog and Nefertiti first printing
Gabik87
(@gabik87)
Dear all,
here my first objects printed from SD card. I've a Prusa i3 mk3s.
Any suggestion for improve?
I printing with compensation of Z -1.000.
Thank in advance for your advice
Attachment removed
Napsal : 24/09/2019 9:08 pm
rmm200
(@rmm200)
RE: frog and Nefertiti first printing
Pre-sliced GCode? Material? Smooth sheet I take it?
Bottom of frog first layer and brim looks good. Frog will actually print with no brim on PEI.
Napsal : 24/09/2019 9:33 pm
Gabik87
(@gabik87)
MK3_PLA_Treefrog_150um_variable_1H_25M.gcode this is a gcode inside my SD card.
silver PLA inside the kit. smooth sheet.
Napsal : 24/09/2019 9:43 pm
Gabik87
(@gabik87)
Ther.s some one to help me!?
For the line on surface of the frog and face of Nefertiti?!
Thanks so much of your help!
Napsal : 28/09/2019 2:36 pm
The Nefertiti chin is a common overhang artifact.   There is no simple solution to getting perfection on such prints: increasing print time, customizing supports, reducing layer heights to minimum, all can help.
The top of the head is by design: it is a replica of a stone carving that has texture.
Your layer 1 (Live-Z adjustment) looks good on Nefertiti, but a bit high on the frog.
This area of the frog looks like your filament tension screw should be tightened to improve Bondtech traction.  It looks like the gears are slipping once in a while causing under extrusion.
And this issue on Nefertiti's face is often loose belts (or even belt drive gears).
Napsal : 28/09/2019 10:27 pm
1 lidem se líbí
Gabik87
(@gabik87)
@tim-m30
Dear thanks so much for your advice, but how modify tension screw?!
For layer z you mean to increase the compensation?
Sorry for this questions but also I wnat to help people here, if my printer work well
Napsal : 29/09/2019 4:04 pm
Posted by: @luperto-gabriele
@tim-m30
You simply turn the screw to increase tension on the Bondtech idler gear.  Read the printer manual.
Live-Z is adjusted to improve layer 1 height, quality, and adhesion.  Read the printer manual.  Also search and read Jeff' Jordan's Life adjust my way article on these forums.
Napsal : 29/09/2019 6:31 pm
