Fresh setup – continuous beeping
Hi Prusa Community,
I have just finished the MK3S+ kit assembling. I was very careful about assembling and about making the cable connections.
I gues have spent 2x much time as it needs.
Trying the first calibration steps: The LCD shows me what to do, but after few seconds after starting a loud beep can be heard countinously from the machine.
It doesn't shut up this loud beep at all. Pressing "X" will restart the machine, but a beeping sound start again countinously. This way, not possible to configure the machine, jus turning it off.
Please help what to do.
RE: Fresh setup – continuous beeping
Does it say M112 Warning on the screen by chance when it does this? If so, I've got this same problem and it started with the latest firmware update.
I posted a bug on GitHub regarding it: https://github.com/prusa3d/Prusa-Firmware/issues/3987
Aaron
Skip setup then do it manually under calibration in menu
Contact Prusa Support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
