Flow tuning [persistent
MrMik
(@mrmik)
I have recently assembled the MK3 kit and I have a problem with the Tune>Flow setting not resetting itself.
My first print was made from a file sliced for my older Pruse i3 MK2s, and it had a EM 1.05 filament setting in it. This caused over-extrusing half-way throught the 14hr print, which I resolved by using Tune>Flow>95% . The rest of the print from there on was perfect.
After the first print finished, I measured filament length pushed into the extruder vs what was requested, and it was near 100% accurate. Very nice!
However, since then every print shows Flow 95% if I check in the Tune menue during printing.
I am quite convinced that I have pressed the reset button several times, and pulled out the power plug several times since I tuned Flow to 95 %, but it stubbornly keeps popping back up at 95% with each new print.
I have reset the Tune>Flow to 100% several times but it comes back as 95% with each new print.
Even when I set Tune>Flow>100% during a print, and then leave the printer on and restart a new print, it reverts to 95% flow.
What can I do to stop this?
Any hints will be much appreciated, Mik
Postato : 04/06/2018 2:48 pm
john.v11
(@john-v11)
Re: Flow tuning [persistent
Are you using Prusa's Slic3r? If so, the flow rate is being set by Slic3r.
M221 S{if layer_height<0.075}100{else}95{endif}
This is found in Printer settings -> Custom G-code -> Start G-code
Postato : 04/06/2018 5:18 pm
Hi Mik.
Look in your start Gcode in the slicer. There is probably a conditional line that sets 95%flow for all layer heights in excess of 0.075mm.
This is probably what is causing your issue
Regards Joan
Postato : 04/06/2018 5:22 pm
MrMik
(@mrmik)
Thank you Joan and John,
I found it in the Start g-code:
M221 S{if layer_height==0.05}100{else}95{endif}
This line (or a similar one) was not present in the previous Slic3r version, or maybe it was, but I had been using my own custom Printer settings including start g-code for a while.
Looks like I'll have to do another print without changing the Flow rate manually, to see if it gets even better. 🙂
The last print came out near perfect, maybe it gets even better when I stop interfering!
Funny coincidence that I set the Flow rate manually to 95% for the first print (sliced for MK2), that red herring has led me astray for several days!
Postato : 04/06/2018 10:02 pm
