First Start Error
tok_on_prusa
(@tok_on_prusa)
First Start Error
Hello there,
I proudly finished the assembly of my new MK3S kit. I think, that all is right, i have double checked all the steps and no parts were over in the end.
So I desided to start the selftest and got in trouble: the printer start's, and the lcd show's the language-menu. Here i can select english or in my case german and press the button. The language does not matter, the result is the same: the printer  makes a click-noise and restarts with the language-menu. And so on. I also tried this with and without plugged sd-card. If the sd-card is plugged in, i can read for a very short time  "Sorting files…", then the printer reboots.
What can I do now? How to debug? I suspect it has something to do with the power supply. The power supply makes light noises.
 Thank you for your help!
Veröffentlicht : 20/05/2019 8:24 am
Vojtěch
(@vojtech)
RE: First Start Error
You need to push the knob, not the X button.
Veröffentlicht : 20/05/2019 10:19 am
