First print - what is wrong?
Just assembled my printer - selftest and calibration was OK. I spent some time calibrating first layer - it seems fine right now.
My problem is that one part of the whistle is not straight. Everything is shifted - few mm after first layer. After that it returned to correct position. What could be the issue please?
Opublikowany : 04/04/2021 3:25 pm
RE: First print - what is wrong?
That looks like a loose pully on the X-motor. Re check that you tightened the pully in the right order. start with both crubscrews loose and than first tighten the one on the flat on the motor shaft. After that tighten the other crubscrew.
Opublikowany : 04/04/2021 5:49 pm
Topic starter
answered:
@baklin
That was it. Thank you very much.
Opublikowany : 05/04/2021 9:03 am
@ondrejs
He beat me to the answer. Happy printing!
Opublikowany : 05/04/2021 3:09 pm
