First Print Stuck in Loop
JWP_311
(@jwp_311)
Hi!  I just finished assembling my printer and after passing all the initial setup and calibrations and getting a good first print layer calibration, but when I go to print from the SD card, the Printer seems to get stuck in a loop of asking me to first unload any filament, and then to load the filament.  I currently not able to print anything, and I do not know why it is getting caught in this loop.  I've tried running through the setup process again and keep cleaning the nozzle, but I still cannot get it to work.  If anyone has any advice on how I can fix this it would be great!
Napsal : 08/04/2020 1:12 am
RE: First Print Stuck in Loop
Posted by: @jackp311
First, simply deactivate the filamentsensor in LCD settings menu and try again. I think you have a problem with an incorrectly adjusted sensor.
Napsal : 08/04/2020 2:15 am
1 lidem se líbí
