First Print - I am sure that this is not right.
Pieter-Michiel
(@pieter-michiel)
I just finished my assembly of the Mk3S and I made a print of the first file on the provided SD card.
I am guessing that the model shifted at about the middle of the print, but I am not sure what else caused this print to come out like this.
Please let me know what you think could be the cause -- that is after you finish laughing... 🤣 🤣 🤣
Thank you.
Postato : 29/06/2020 10:01 pm
HeneryH
(@heneryh)
RE: First Print - I am sure that this is not right.
Did you use the proper material to match the settings in the gcode?
Maybe a material mismatch with the temperature settings?
Questo post è stato modificato 6 years fa da HeneryH
Postato : 29/06/2020 10:15 pm
HeneryH
(@heneryh)
I just looked at the files on my card.  Seems like most of them are for PLA.    Was that what you used?
Postato : 29/06/2020 10:19 pm
Pieter-Michiel
(@pieter-michiel)
Thanks for the replies.
I used the 'Silver' PLA roll that came with the basic kit and I noted the 210 degrees setting for PLA.
Postato : 29/06/2020 10:31 pm
CovertPluto3502
(@covertpluto3502-2)
Check your belts, they seem like they are slipping. Tighten all of the screws and try again.
Postato : 30/06/2020 12:28 pm
