First print after assembly
Antonio
(@antonio-2)
Hi everyone, finally I got my m3ks and I’ve build it in some day’s ‘cause work.. today finally it’s finished, making test, everything ok, I said ok it’s time for the first print, I choose one of the file from sd, the printer made the 9 point calibration then it go to the right corner and want to change filament.. I’ve tried to bring off then follow the instructions where Lcd say to put filament on (again), then it start again 9 point then pull of filament then on again........
what I do wrong? Thanks
Respondido : 13/06/2020 8:47 pm
Antonio
(@antonio-2)
RE: First print after assembly
New firmware already flashed
Respondido : 13/06/2020 8:50 pm
Antonio
(@antonio-2)
Already print 1 then 2 of this https://www.prusaprinters.org/prints/8624-mk3s-ir-sensor-spacer-05-mm   but still not working
Respondido : 13/06/2020 9:55 pm
Posted by: @antonio-garello
I think the filament sensor is not properly adjusted: https://help.prusa3d.com/en/article/selftest-mk3-and-mk3s_2045
Respondido : 13/06/2020 11:20 pm
