First layer problem only with circles
broconne
(@broconne)
I have recently been printing a bunch of gridfinity items and to increase the speed I have switched to a .6mm nozzle.  I tightened the nozzle using a torque wrench to the specifications of 2.5 Nm.
I have tuned the first layer and it looks good to me.   Right now I am at -.700, if I go to -.750 I get artifacts on the first layer.  I am using Overture PLA with the default settings for that filament in PrusaSlicer (2.5).  The first layer has a height of .2mm.
What I am seeing (picture attached) is that across the first layer is fine unless there is a circle in it.
Any suggestions on what I should be investigating to fix this?
Opublikowany : 15/03/2023 3:51 pm
Yur pictures are not quir sharp enough to be sure but your first layer may be a bit low, too much squish, and there is something on the print-sheet - smears? debris? that may be interfering too.
A thorough clean of the print-sheet and revisiting your first layer 'Z' calibration should fix it.
Opublikowany : 15/03/2023 5:06 pm
broconne
(@broconne)
RE: First layer problem only with circles
The print sheet is clean.  I used dish soap recently and use IPA (91%) in between uses.  I think that is just an artifact of me cropping out the rest of the picture which zoomed it in.  I can try and take a closer picture.
I will re-do my 1st layer calibration, but those have been coming out perfect.  The only time I get these artifacts is when it is trying to print circles (it seems).  Is 1st layer calibration impacted by the shape?
Opublikowany : 15/03/2023 5:44 pm
gilesjuk
(@gilesjuk)
Try printing this calibration pattern, it helped me dial my first layer in perfectly. You can gradually adjust the value until it looks right. https://www.printables.com/model/251587-stress-free-first-layer-calibration-in-less-than-5
Opublikowany : 15/03/2023 10:44 pm
If adhesion is low, for whichever reason, it's more likely to pick up on the curve.
Opublikowany : 16/03/2023 12:31 pm
broconne
(@broconne)
Posted by: @gilesjuk
Thanks. I was using that to adjust my first layer and agree its a nice design to use.  I am now starting to think my mesh bed just isn't level.  I printed the bed level test and in the same corner (and some others) I have issues where as the middle is fine.
Opublikowany : 16/03/2023 1:06 pm
Crab
 Crab
(@crab)
One thing I recently learned is that you can lower the Z until you get some "waviness" in the top surface as you shine a light at it. This waviness indicates you are a bit too low and to back off. This is a great indicator to help really tune that first layer and helped me a lot to get the Z as low as possible but not too low. I haven't used a 0.6 nozzle so don't have any experience with that size.
Opublikowany : 16/03/2023 2:23 pm
This article might help - use with caution.
https://help.prusa3d.com/article/bed-level-correction_2267
Opublikowany : 16/03/2023 4:37 pm
Crab
 Crab
(@crab)
You also might want to consider physically leveling your bed. There are some good bed visualizer plug-ins for Octoprint and a good bed mod that uses 3ID x 7-8OD silicon tubes to replace 8 standoffs underneath the HeatBed. I just got my tubing and plan to do it in the next few weeks. Requires a new z calibration and setup but gets you really flat. Bed Level mod
Opublikowany : 17/03/2023 10:35 pm
broconne
(@broconne)
Thanks.  I didn't know about that mod.  So I ended up doing the nylock nut mod.  That made my bed a lot flatter but didn't fix the entire problem.  I ended up cleaning the bed with acetone which fixed some bed adhesion issues I was getting in the corners.
I will say, I do after doing this question the accuracy of the bed leveling sensors because when I was running this test in places like the back center I would have a layer that was separated and the plugin was telling me to tighten the back center which I think would make it further away from the nozzle.
I do think I am at a point where it should be functional across the entirety of the bed.
Posted by: @crab
Opublikowany : 18/03/2023 4:31 pm
