First layer printing blobs and strings after faulty print
kevin.a18
(@kevin-a18)
Hi all -
I work in a hospital research group and we just recently got an i3 mk3 and are looking to 3D print a full size skull model. We managed to print one (~60 hrs of print time), but when we went to print it again, we came back the next morning with a mess of filament everywhere (see attached). We also noticed that the nozzle fan component had broken off - which we managed to reprint a OK version of to continue using the printer. Not sure if a collision happened or what.
We went to do some other prints (and first layer calibrations) but the prints are very stringy and bloby (see attached image).
Now - we have re-calibrated the printer completely. The first layer sticks quite well, but the nozzle gets caught up in the blobs and stringy bits and we can never get past the second layer of a more advanced print. I have decreased the extruder multiplier to 0.9 and have taken off the nozzle and cleaned it out. Calibration of first layer sticks, except on some of the corners (as seen in the attached image). I have learned that a 99% isopropyl alcohol is better than 70%, which we'll try out.
Keen on any other suggestions/experiences/solutions that folks can offer. Thanks in advance.
Publié : 16/10/2018 12:55 am
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: First layer printing blobs and strings after faulty print
First use the info in this thread to adjust your Z
https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html
once that is done and you are sure your nozzle is clean (when you load filament with the extruder about 1/2 way up the Z) see that drops down mostly straight ... slight wide curls as it drops is normal ok.. but if it darts to one side or it hangs up a bit on the nozzle or heater block clean it again... get some cleaner filament extrude a few inches of it and then do cold pulls ... then back to the loading of your printing filliment and do the load and observe...
You can also reduce the problems once things are clean and printing normally with one of these heater condoms get the genuine e3d brand to be sure they will fit...
https://smile.amazon.com/gp/product/B077TKBKR3/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Publié : 16/10/2018 4:33 am
