First layer print issues
florin.a
(@florin-a)
Hi all,
I recently purchased the mk3 model kit and went through the assembly process. All was good until a couple of days ago as I haven't been using the printer and I now see that I am experiencing calibration issues.
The first layer calibration test prints ok; but when I print a larger object I get areas that are either not sticking or are too close to the bed as per the attached image.
Any help would be greatly appreciated in understanding what should I do next to sort this out.
Many thanks.
Postato : 11/01/2019 2:07 pm
RH_Dreambox
(@rh_dreambox)
Re: First layer print issues
If the first layer has a glossy surface then the problem may be fat spots on the bed.
But if the surface is matte then the Z level is too low and you have to raise the nozzle a little bit.
It can also be a combination of dirty bed and a too low Z level.
The bed is best cleaned with detergent and water.
Postato : 15/01/2019 9:34 am
