First layer issues? Look here!
Hey guys,
Seeing a lot of people repeatedly calibrating PINDA, temp, etc trying to get that first layer to work. Just wanted to point out a bug found by stahlfabrik a few hours ago: https://github.com/prusa3d/Prusa-Firmware/pull/514
I'm about to start testing this myself, and figured some of you might like to help. Here's two versions of this firmware with the mesh leveling "fix" above applied. Please go update the pull request with your results so we can get this pushed in quickly:
Before anyone asks, Linear Advance has no bearing on this that I am aware of and should only be used by sdcard users that understand the issues behind it being enabled.
Hopefully this works and can hold us over until an official fix. 🙂
My MK3 Parts: [Bowden] [New Shoes] [TPU Micro Springs]
Re: First layer issues? Look here!
I don’t know tons about github, but I’m seeing lots of versions of firmware pop up on the forum each with there own tweeks and improvements. Its great everyone is putting the time in.
What confuses me is how do you know if the pull requests are adopted back i to the original prusa firmware, is it when they then become closed?
Thanks
Thanks
Closed doesn't necessarily mean that it was added to the MK3 branch. Usually a dev makes a branch to test new code, then when they are ready they put in a pull request (sometimes called a merge request). If Prusa thinks the code is good, they merge it in to the MK3 branch.
Here's an example of some new code that was merged in, note the merge commit at the bottom of the comments: https://github.com/prusa3d/Prusa-Firmware/pull/509
You can also look at the commits on the MK3 branch. Merges will show up there too. 🙂
Hej Brigandier!
Awesome! Thank you for spreading the word!
My Bug fix has nothing to with LA - just if anybody wonders. In general I think the first layer issues have nothing to do with LA being deactivated. No, I do not think: I KNOW from a lot of pain...
I find it funny that now several custom firmwares are making the rounds.:-)
Lets hope Prusa reviews my pull request quickly so it is introduced into the stock firmware.
Thanks
Thanks 🙂 GitHub takes some working out for me still lol
I tried this firmware out and somehow it broke connectivity to Octoprint. When I try to connect the I3 shows the boot display and just gets stuck there. Flashed back to the official 3.1.2 firmware and it's fine again.
Interesting. If you went with the no LA option, it's literally a - changed to + difference from what is on the Prusa downloads page, assuming they compiled straight from the MK3 branch.
Exactly. Did did you use the firmware with LA? Or without?
I would flash the firmware again. If Brigandier put here my build (@Brigandier: Did you?) then the first thing after boot is a warning screen where you have to confirm that this is an unofficial build and you know what you are doing. While this screen is shown, serial communication is blocked (The setup() function does not even finish). So maybe you can also try to disconnect octoprint until you have confirmed that start up warning screen!
The "no LA" option is the current MK3 branch with an edit to line 3762 of Marlin_main.cpp to change - to + per the pull request. I can confirm I am getting the "use at your own risk" prompt as well, so I suspect you're correct. Wasn't aware serial communication was blocked before the prompt is confirmed, good to know. 🙂
I'm getting first layers issues, and assumed part of it WAS the LA, since it's overstuffed corners where I get the lift, every time. That said, it's fairly consistently in the upper right corner of the bed, which I'd like to see better leveled. My top surfaces have not liked the LA issue at all. I hate to change two things at once, but...
In short, I'll give the LA version of this a whirl in a bit, get back with results.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
I agree on not changing more than one thing at once. I have only included the LA enabled version because I prefer it enabled and only print from sdcard, it has zero bearing on this issue. Just thought having the LA option might prompt others to test the code edit. 🙂
That may be the only code change, but whatever compile flags result in the warning message about it not being official firmware results in it interfering with Octoprint's ability to connect.
It'd be great to get a version of this without that warning...
Octoprint causes the printer to start from boot when it connects, so I'm guessing this is why Octoprint is broken. There's no way to disconnect octoprint until after that warning screen because it's the Octoprint connection in the first place that results in the printer booting again.
Did some digging, in Configuration.h:
// Firmware version
#define FW_VERSION "3.1.2"
#define FW_COMMIT_NR 231
// FW_VERSION_UNKNOWN means this is an unofficial build.
// The firmware should only be checked into github with this symbol.
#define FW_DEV_VERSION FW_VERSION_UNKNOWN
#define FW_REPOSITORY "Prusa3D/MK3"
#define FW_VERSION_FULL FW_VERSION "-" STR(FW_COMMIT_NR)
// Debug version has debugging enabled (the symbol DEBUG_BUILD is set).
// The debug build may be a bit slower than the non-debug build, therefore the debug build should
// not be shipped to a customer.
#define FW_VERSION_DEBUG 6
// This is a development build. A development build is either built from an unofficial git repository,
// or from an unofficial branch, or it does not have a label set. Only the build server should set this build type.
#define FW_VERSION_DEVEL 5
// This is an alpha release. Only the build server should set this build type.
#define FW_VERSION_ALPHA 4
// This is a beta release. Only the build server should set this build type.
#define FW_VERSION_BETA 3
// This is a release candidate build. Only the build server should set this build type.
#define FW_VERSION_RC 2
// This is a final release. Only the build server should set this build type.
#define FW_VERSION_GOLD 1
// This is an unofficial build. The firmware should only be checked into github with this symbol,
// the build server shall never produce builds with this build type.
#define FW_VERSION_UNKNOWN 0
Looking like Prusa's build pipeline automatically changes this when they do RC or GOLD releases so it doesn't error out. Anyone compiling directly from source will have the error message. Of course, you can pull it and make stahlfabrik's change plus edit this bit of code here to force it. 😉
The bit you are wanting is this line:
It gets checked later on to see if it's set to FW_VERSION GOLD or FW_VERSION_RC to determine if the message should be shown or not. You can change the above define line to the following:
#define FW_DEV_VERSION FW_VERSION_GOLD
and it should go away; however, I don't think Prusa would appreciate it if you posted it up, thus why I am giving you the instructions vs posting a hex with the changes. 🙂
Interesting, I had added in a preheat for the pinda at the start of each print, but using this firmware should mean I can remove it?
Way too much work, I'll just wait for them to merge this and get an official firmware 🙂
Yes. That is the plan
I am sorry to say but for that issue this fix might help nothing because it is not about temperature and repeatability.
From your description your problem is very consistent. Maybe you have a warped bed or need to experiment with the +-50um bed level correction settings?
Of course potential temperature fluctuations will not HELP with your problems and stock firmware either:-)
With the z-offset fix I am definitely seeing more consistent first layer height, but I am also seeing a portion of my bed that seems to stay consistently low (the center). It's close enough most prints work, but there's a visible variation across large parts. I haven't seen this +-50um setting you mentioned, is it hiding out in the menu or is this another code change someone has floating out there? Curious to try it, I am guessing it allows the mesh level correction to correct a bit further? 🙂
Thanks
It is somewhere in the menu. For the front, back, left and right you could set a manual offset of very small steps in a small range. So if your middle is to high, you theoretically could raise the front, back, left and, right.
You will find the infos here:
https://help.prusa3d.com/l/en/article/TPGip0OmaP-bed-level-correction-kit-only
Oh and THANK YOU! You are the first to finally report back that my fix improves things:-) Have gotten no feedback yet what so ever. I am still 100% convinced that this is it.
