Re: First Layer Funkiness
Your z offset is set too close to the bed.
Postato : 23/04/2018 3:51 am
Topic starter
answered:
Looks like that did it. Thanks!
Postato : 23/04/2018 6:34 am
What is your Z offset set to? I have a similar issue.
Postato : 02/05/2018 7:34 am
One man's z offset is completely different from another. You know, like one man's um ... 🙂 Assuming you are a man of course.
And yes, as I said in your other thread, your z value is probably wrong. So, you need to print out some calibration squares to see how your z offset looks. There are plenty around, just check on Thingiverse for example. This also has the advantage of allowing you to see if your bed is level.
Postato : 02/05/2018 7:55 am
