First layer calibration help
Grendelrt
(@grendelrt)
Hello all, I watched the first layer videos and understand the concepts. But I think I need some mechanical adjustment to help the live Z changes in software. I calibrated the PINDA like in the guide and run the openeing calibration and the paper does not move. Then I run the z adjustment calibration, and I can not get the nozzle close enough to the sheet ( I was at like -3), so I am guessing I need to adjust the PINDA sensor again to help get the nozzle closer to start with.
When doing the original PINDA adjust the first time the paper moved, so I moved the PINDA down and it looked like in the guide pic, and the paper no longer moved. I am guessing I need to move the PINDA up some to get the nozzle closer to the heat bed in that calibration, I have feeling when I do that the paper may move, since that's what happened prior to moving it down. Can I ignore the paper slightly moving? Is the correct set of adjustments to make to get a better starting point on the nozzle and hopefully not hit over a -2 on live z?
Dieses Thema wurde geändert Vor 6 years von Grendelrt
Veröffentlicht : 05/09/2020 2:25 pm
Grendelrt
(@grendelrt)
RE: First layer calibration help
It wont let me edit the post for some reason now, but the secondary question I have to this is the PINDA sensor, when it was too high and the paper moved, I had to move the sensor down. Did this increase the accuracy of the sensor so then it found the right spot or is there a correlation with PINDA height and nozzle height (PINDA up -> nozzle down, PINDA down -> nozzle up)? I guess if its the first I shouldn't mess with the PINDA since it is not hitting the bed with the nozzle at this point and passes. And I am not sure how to fix my live Z adjust to get the nozzle down to the bed.
Diese r Beitrag wurde geändert Vor 6 years von Grendelrt
Veröffentlicht : 05/09/2020 2:39 pm
3Delight
(@3delight)
Moderator Moderator
The lower the PINDA, the higher the nozzle, and visa versa, is how it works.  It sounds like you need to raise the PINDA a little so it is just above the tip of the nozzle if you are having to adjust the Live Z that much.
Veröffentlicht : 05/09/2020 3:05 pm
Grendelrt
(@grendelrt)
@3delight
Perfect, that's the info I needed, I didn't want to keep adjusting over and over without the correlation. I will redo the PINDA again, thanks.
Veröffentlicht : 05/09/2020 3:30 pm
