First Layer Calibration Fails, not enough filament flows through extruder
skout
(@skout)
I’ve recently finished assembling my i3 mk3s. When I get to the first layer calibration things do not go well at all even though it passes all the tests correctly. I have cleaned out the nozzle, disassembled it and changed the tube, tightened and loosened the gears for the extruder, cold pulled it and tried everything I have seen in the forums. Nothing seems to help.
All I get is a very thin amount of filament coming through, sometimes no filament comes through even though during the initial extrusion test it came out just fine.
Any other ideas out there? Thanks for the help!
This topic was modified před 5 years by skout
Napsal : 12/09/2020 12:46 am
Peter M
(@peter-m)
RE: First Layer Calibration Fails, not enough filament flows through extruder
Move extruder higher up, and extrude filament, look if it is thick enough, and if it's extrudes in a straight line.
Tighten the spring of extruder?
Extrude 100mm of filament and check if the filament uses the 100mm, look for a how to on google.
You could try a new nozzle , it could be partial clogged.
Higher temperature could also help.
This post was modified před 5 years by Peter M
Napsal : 12/09/2020 9:43 pm
skout
(@skout)
@peter-m26
When I extruded 100 mm, it came out as 600+mm. It comes out much thinner than it goes in.
Napsal : 12/09/2020 11:09 pm
skout
(@skout)
Loosened and tightened the spring with no change in result.
I performed a cold pull, and this is what it looks like...
Napsal : 13/09/2020 12:04 am
MartyS
(@martys)
Posted by: @skout
@peter-m26
You want to check that when you extrude 100 mm, 100 mm of filament goes into the extruder.
Easy way to do it is to put a mark on the filament at something like 120mm above where it goes into the extruder, then check if it's at 20 when you extrude 100 mm.
Napsal : 13/09/2020 1:43 am
skout
(@skout)
@mrschultz02
Got it, thanks for clarifying. I did that and it worked correctly. Marked it off, moved extruder +100 and the mark moved 100.
Maybe I am just having problems with it adhering to the sheet? Not sure how much thinner the filament is supposed to come out than it goes in.
Napsal : 13/09/2020 6:19 am
With the standard 0.4mm nozzle, the filament coming out is a lot thinner that the filament going in.
have you turned on 7x7 mesh bed levelling,?
Is your build plate extremely clean?  I wash mine...
are you still using the Prusa first layer calibration tool?
I find this method easier to managed...
Napsal : 13/09/2020 9:42 am
skout
(@skout)
Thank you everybody for responses and help.
I greatly lowered the z axis, cleaned my steel sheet and had success.
Noob Level 1 accomplished. Fail fast they say. Thanks again!
Napsal : 13/09/2020 4:45 pm
