First check issues - Calibration failed! Check the axes and run again
neps
 neps
(@neps)
Just finished the build and can't get past the calibration. Moves up and down the Y axis a bit when calibrating Z and then fails. Here is a video
thanks for any advice!
Respondido : 25/04/2019 11:18 pm
vintagepc
(@vintagepc)
Miembro
RE: First check issues - Calibration failed! Check the axes and run again
Something is binding on the Z axis and preventing it from going up further. It also sounds pretty crunchy. Check that the bearings all move freely and that the Z-nuts are not binding. Can you move the Z up further if you manually twist the lead screws by hand with the printer off?
Respondido : 26/04/2019 12:56 am
neps
 neps
(@neps)
thanks for the reply! I am able to manually move the Z axis all the way to the top within the SETTINGS screen.
what's the best way to check that the Z-nuts aren't binding?
Respondido : 29/04/2019 12:18 am
Posted by: neps
An easy way is to act like you are starting a print so you get the X-Axis to the bottom of thee Z-Axis rails.  Then support the X rails with a box so it can't drop onto the bed.  Remove the screws holding the T-nuts to the X-Axis supports.  They are then free to turn all the way up the lead screws...
To reassemble the X-Axis, turn the T-nuts back down to the supports and screw in place. Then, you MUST drive the X-Axis to the top of the frame (press and hold the control button to get to the X-motion settings) and drive the axis upwards util you hear it colliding with the top stops.  Ensure both sides are against the stop.
The printer X-Axis is now recalibrated.  But a test of Live-Z is probably in order, to be sure all is well.
Respondido : 29/04/2019 12:29 am
neps
 neps
(@neps)
Here is a video with a few different clips
- general noise
- left side moving but right side not
- moving the Nut manually - at first it looked like the right had interference - it hits the rod a bit more
- but then I started to notice the Nut free spins downward - the right side moves down a lot smoother than the left
Respondido : 01/05/2019 2:18 am
