First build problem
First of all sorry. if my english to poor to understand.
so. I just bought and build the printer full with all the instruction guide say. I follow it all through
after I complete the printer and I test prusa logo that included in SD card.
the result too much stringy.
Then. this this time I download stringy test from thingverse and print it with Slicer PE. with stock config and 2 custom
First print
Stock no changing or whatsoever
Second print
I change the retraction speed from 35mm to 45mm.
third print
I change the retraction speed from 35mm to 60mm. hotend temp from 215 to 210.
the result are same. I and stuck here. so if I move foward this condition is no good.
so. I run seftest and the result are okay. all correct.
but there is a bit problem maybe this is the main source of problem
in the handbook page 72 it mention about the right value is 275 +/- 20 are good
do I need to tighten the X and Y belt again?
the last problem is autoloading filament.
I thought when I preheat PLA. and I insert filament into the hotend mouth. it will automaticly take the filament by itself. but when I put it in. nothing happend. because When I enter the "autoload filament" it say. "Autofilament is active. just press the knob and insert the filament" when I do that nothing happend. is that normal?
So. I check the handbook about. to look out for the Sensor state.
The IR say 0. it supposed to be 1. 0 mean nothing. 1 mean fill. but there is filament already in the hotend.
can anybody help this Through This. I already in dead road. I am really really new in 3d printing
Thank you
