First benchy after assembly
Chealton
(@chealton)
So printed the prusa logo came out good and did the whistle again came out good. The real test the benchy, what can be adjusted to smooth this up?
Respondido : 16/11/2021 1:10 pm
Dan Rogers
(@dan-rogers)
Practically perfect , move on
They don't come out much cleaner than that.
Respondido : 17/11/2021 9:29 am
I would rate that print as good enough for the first month.
Every user builds their printer slightly differently so during the first few weeks of use the printer will run-in and settle its parts together; then you will have to go over the basic maintenance checks, lubricate and recalibrate. Even if you got everything dialled in perfectly today, it would all need re-doing.
Better to settle, temporarily, for a basic working printer and get some useful printing done, make your early mistakes, establish a routine and generally get used to the process. Then when you do your one month service you can take extra care knowing the new settings on your now stable printer are likely to last for several months.
Respondido : 17/11/2021 5:35 pm
