First Benchy! A few problem spots though
Pixel Visions
(@pixel-visions)
I just printed my first benchy, and a second after correcting the Z adjust to get A flat bottom and test a temp reduction.  Both models have the same small issues, and one major one.  I am printing from the included SD card, and my printer was pre-assembled. Great circle on the chimney, so I don’t think any belts are loose.  Any ideas/recommendations, especially to resolve the big pits in the back on the left side of the plaque?
Pits near plaque on seam
Deformation/blobs on arch
Flat top of windowframe
Zits on wheel
Small pits on hull
Respondido : 24/01/2021 12:40 am
Pixel Visions
(@pixel-visions)
RE: First Benchy! A few problem spots though
Huh, none of my pictures posted.  Looking into it.
Esta publicación ha sido modificada el hace 5 years 3 veces por Pixel Visions
Respondido : 24/01/2021 2:09 am
Robin
(@robin)
I can‘t see the pictures in your post, but: that sounds very familiar. I had basically the same issues with the benchy from the SD and the filament that came with the printer. Most of the problems disappeared when I used my own g-Code, sliced with the current version of PrusaSlicer, all issues where gone, when I additionally used different filament.
I recommend you try that before wasting more time (like I did) on troubleshooting.
And, yes, the g-Codes on the SD should be up to date and the stock filament should not cause any trouble... but in my case, they weren’t, and it was.
Respondido : 24/01/2021 9:18 am
Robin
(@robin)
See: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/update-small-holes-in-benchy-3d/
Respondido : 24/01/2021 9:20 am
Pixel Visions
(@pixel-visions)
@robin
Thank you so much for the link, I reposted with working pics, but its waiting for moderator approval.  I noticed my file for bench on the sd card was from 2018, while the one that downloaded with prusaslicer was just updated this month, so maybe this gcode will have better results.
Respondido : 24/01/2021 10:50 am
1 les gusta
