Filling Cracks
kenneth.t9
(@kenneth-t9)
Filling Cracks
My printer just finished a model of 'Winged Victory" (also known as Victory at Samothrace) and besides problems removing all of the supports, my major concern is a crack between the top winged half and the bottom half with the pedestal. What are users using to fill cracks on models?
I will of course sand the whole model to reduce the evidence of PLA filament but the crack when I glue the two pieces together will clearly show. The filament is ivory so whatever I use to hide the crack will have to be color matched.
I was thinking of something like "spackle"; is there a plastic version that would harden but not shrink.
Suggestions?
ken tompkins
Publié : 11/04/2019 3:17 pm
vintagepc
(@vintagepc)
Membre
Re: Filling Cracks
Automotive body filler is often used for this, that should meet your needs.
Publié : 11/04/2019 4:00 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: Filling Cracks
Weld on #16
https://www.amazon.com/IPS-Weld-Acrylic-Plastic-Cement-x/dp/B0149IFA9O
or
Loctite Super Glue Gel
https://www.amazon.com/Loctite-Super-2-Gram-Tubes-1399965/dp/B0041NTBZM/ref=sr_1_5?keywords=LOCTITE+SUPER+GLUE+GEL&qid=1555008157&s=hi&sr=1-5
full details here
https://hackaday.com/2018/02/07/locally-sourced-pla-adhesive/
post printing processing is a vast subject and there are whole websites dedicated to it as well as youTube channels
https://www.google.com/search?q=3d+print+finishing&oq=3d+print+finishing&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
you don't need to fully sand away every trace of the layer lines, use a high build or regular spray on plastic primer as folks that make plastic model kits use as their first step after light sanding I tend to use this primer for everything I paint
modelers tend to use this
Tamiya TAM87042 87042 Surface Primer L Gray, 180ml Spray Can, Light Gray
https://www.amazon.com/Tamiya-Primer-Gray-180ml-Spray/dp/B0000WS014/ref=sr_1_fkmr0_1?keywords=tamiya+high+build+primer&qid=1555008691&s=hi&sr=8-1-fkmr0
Publié : 11/04/2019 8:57 pm
